I have a Fisher PRO C that is taking on water through the live well drain. I think the drain line from the transom to the live well has become disconnected at the live well tank. Anyone ever heard of a similar problem? Is there some sort of back fill float in the line that prevents water from coming up the line when the boat is in the water? When I pull the plug on the live well the water drains into the boat (which I can hear) and does not drain through the line to the drain hole so I am assuming the hose has come disconnected.
Any ideas or help would be most appreciated. Thanks.
