I have 1999 5.0L GM V8 with Volvo penta SX drive. I had to replace the upper bearing carrier housing since the old one was corroded into the pivot housing and broke at removal. I have new front and rear bearings (matched part numbers), a new pretention sleeve, new seal & c clip and existing pinion gear... I had a autoshop remove old and press the the new bearings onto the pinion gear. and press the outer bearings to the new bearing carrier assembled with new pretention sleeve and bearing. My problem is I still have 1/8" end play when it is all pressed together. The manual says to assemble untill endplay is gone. The only thing holding it would be the pretention sleeve. How much force is required to "crunch" the sleeve a bit???
Thanks for any info.
