herbeapuce
- Jul 13, 2007
- 14
Hi. I just bought a 1999 Honda 2HP 4 strokes, model BF2DXLJ, serial number 1001xxx. So I pay the guy. I get home. I read the entire instruction book that came with the Honda. I fill up the gas tank. Check engine oil, Then I fill up my garbage bin with water. I install the Honda on the bin and I start the engine. Everything seems smooth. No smoke I do the test for 4 minutes or so. Then I turn off the engine. But when I looked at the water in my garbage, there was oil stains all over the surface of the water. Not much, but enough to make me nervous....so right after this, I checked the gear oil... the color was a bit milky, opaque.
I did a second test with a different bin and same result?
I don't know anything about outboard engines, so my questions to you are:
Is a bit of oil in the water normal?
What?s the color of good gear oil? I don't know what gear oil looks like..
Where could be the oil leaking from?
Also my propeller is made in Plastic, is this normal? Or this is an after market cheaper prop?
Thanks for your help
Stef, Montreal
Stef, Montreal
