I have had a problem starting the above engine- not starting at all at the moment. Turns over well, compression good, spark is present. Checked spark plugs after trying to start- they are soaked with fuel. Small leak noted at primer valve. Could a faulty primer valve/ primer solenoid cause a non start ?
