FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
my vhf radio will transmit but not recieve.I checked it at the dock.they heard me but I couldnt hear them.my speaker works too.i can hear the weather reports.I got a good 8ft shakespear antenna,whats up?
What kind of radio is this? Could be any of a number of problems. Too many possibilities to go into without knowing the radio model and year if you know it.
I did a search and found out that the antenna wire needs to be at least 3 feet.mine is barely half that.the braided is the "recieve" the center is the "transmit".gonna find out tomorrow......Thanks
Tony<br />Both the braid and the inter are used for transmit and receive. Coax is an unbalanced line where the braid is a sheild and ground and the inter carrys most of the signal both transmit and receive. The length of the coax should not affect your receive. Having less coax than 1/2 wave length can affect your transmit some if your antenna is not a real good match. <br /><br />Can be many things. To start need a lot more info. First thing I would do is open the squelch up until you here static. Also unplug your coax and see if the connector is clean. Put it back in and tighten. Then see can here someone on the same channel. <br /><br />Are you trying to receive in a scanning mode and if so does it stop scanning when some one is talking? Is problem with a certain channel or all channels? What radio do you have?
