MajBach
- Jun 21, 2003
- 564
Hi all. Couple of weeks ago, my gear linkage snapped - which I replaced. The little brass cube ( an adjustment screw of sorts )which receives the push rod is only holding the rod by a couple of threads; for some reason, the push rod did't seem to fit in length like the last one did. One thing I noticed after installing the new cable/sheath was that the neutral safety switch located dead center at the base of the powerhead was not exactly centred when my gear lever was in neutral - it was just barely enough to indicate neutral to the kill switch to allow starting. I'm not sure if this is related to the problem but I mention it anyway.<br />So, after I replaced hte cable, the motor ran and shifted fine. About three trips ago, I noticed when I came to neutral from forward, it took maybe two seconds before the motor actually went into neutral. Going from reverse to neutral was fine. Tonight, when trailering the boat, the motor wouldnt go in neutral at all. AS a matter of fact, even moving the lever to reverse didnt correct this; it went directly from forward to reverse. When I came back to neutral from reverse, it stayed in reverse until I pushed forward and then went into forward again.<br />Any thoughts?<br />Now see prob #2
