priming
jbreen
If you pump up a priming bulb till its hard and you come back after a couple of hours should the bulb still be hard?
kenmyfam
Re: priming
It will lose prime over time. How long depends on how good your connections and fittings are. I prime once a day usually. Prepared to be educated otherwise though, just my personal experience.
Just my 2 cents as well.
jbreen
Re: priming
Thanks for the responses. I am new to this stuff but am learning all i can. Again thank you very much. jeff
tashasdaddy
Re: priming
also when the motor is running the bulb will go soft, as the fuel pump draws fuel thru it.
