Priming the oil line necessary.
jfbetz
I just completed an engine swap (1999 Yammi 250's) and was wondering it I need to somehow prime the oil injection system. The oil resevoir on the engines are full, but the supply lines to remote tank were replaced during the swap. Do these lines need to be primed?
Thanks
rodbolt
Re: Priming the oil line necessary.
no
but word to the wise.
dissconnect the link at the carb shutters, allow it to run a few minutes with the oil link at the WOT position while you crack the bleed screw on the pump.
the reattach everything and go play.
