I have a 88 Suzuki DT175. I have had an issue with cold starts (only cold). I have to do this procedure below to get it to run steady.
- Pump the bulb until its firm
- Push the choke in for 10 sec then turn over
- Starts in about 3-5 turnovers but will stall in 5 secs
- Check bulb and needs to be pumped again
- Pump until firm and repeat
This goes on until it decides its warmed up enough to actually start lifting the throttle up.....then it stays running. This might be 5-10 times through the steps above. It runs fine on warm starts.....loads up sometimes on idle but its an 88. I rebuilt the carbs during the winter and this helped a lot with rough idle but still loads up and has a cold start issue.
Any ideas?
Any ideas?
