Re: Priming Problem
Its a 79 50hp, I just replaced the internal fuel line to the mechanical pump and checked the diaghram.....looks good. So once I finished this I primed the engine to check for any leaks. The person who had it before me put clear lines on the output of the pump. Its goes from the pump tot the bottom carb(which fills) and at that carb theres a T which jumpers it up to the TOP carb, I see fuel trying to get to the carb, but by the time the bulb is hard no fuel gets to it. Basically since I bought it, its not had any power ( or at least as much as it should) brought it to a shop to clean the carbs. He said he fixed the bottom carb, cleaned both and commpression check it and everything was good. I got it back from him and nothing really had changed. Please help, Im ready to drop it off the back of the boat.<br /><br />Cheers,
