sparkroost
Thread starter- Joined
- Mar 23, 2003
- 312
I have a factory V4 140 intake manifold. I have no idea the year, but the primer solenoid connects to 4 fittings on the intake manifold. I took all 4 fittings out and sprayed cleaner/air through them. It seems that I can spray air through the back side and air comes out fast. But if I blow air through the notmal side there is little air coming out. There acting like a check valve, but the wrong direction. Problem I am having is my fuel pump has not enough presure to overcome the fitting. Did some models come with an electric fuel pump with a higher PSI? The fittings also have screens in them. I guess the obvious is to replace them, but I am having a hard time finding them.
