kestrel452
- Jan 21, 2015
- 20
In regards to my 1999 Mercury 15HP 2-Stroke....
I changed the fuel line to a genuine Quicksilver quick connect style line, and replaced the EPA cap on my Attwood tank with a Moeller venting cap (which fit just fine). It was the pre-assembled 8' line with the standard 1/4" thread on one end, and quick connect engine fitting on the other. Had a full tank, and verified that the engine side connector was snapped in place, but the primer bulb just wasn't firming up. Even the crappy Attwood line I had before would firm up pretty quickly after a few squeezes, but this one just wasn't having it. The engine managed to start when i hit the electric starter, though. After leaving the dock and meandering through the no-wake zone to head out, the engine was "sneezing", and continued to do so at times when we were running at less than 1/3 to 1/2 throttle. Could this be caused by a bad bulb????
I also noticed a slight squeal coming from the engine when bringing it down from full throttle that'd last a couple seconds.
The engine should be okay mechanically, I've had it inspected by multiple reputable shops. The only thing that's been done to it recently is the installation of a Permatim hydrofoil (since the inflatable I have it on wasn't planing), and me installing a lower pitch (7 pitch) prop from the stock 9 to bring the RPM's up a little. I sprayed everything with Corrosion X oil, including the thrust washer, spines, prop, shaft spines, and nuts before putting everything on and cranking the prop nut down.
Any thoughts???
Any thoughts???
