Re: Primer Bulb -shouldn't it pump up hard?
Thanks ZmOz, I reused the old Tank end connection ( to a pacemaker tank) on the new bulb and hose assembly, may be this is where I am sucking in air as well?<br />The Fuel filter on the out board only fills 1/2 way when I prime, I see the fuel squirt in, but then it's empty again. No fuel is leaking from the Carbs.<br />I only bought this motor recently and when I get it running it's ok. But I think it's not getting fuel on start up as the fuel pressure is not mantained.<br />I check the tank end for an air leak.
