Fordiesel69
- Sep 18, 2009
- 1,146
Boat Details in signature....
Need to get a ball park value. Below is a list of issues.
Short and sweet, here is what is wrong:
-Transom moves quite a bit when you pull up and down on the drives.
-Starboard 470 engine leaks out cam seals, and has a blown exhaust manifold gasket. Starter seems weak like it needs refreshed.
-Starboard drive trim motor needs refreshed as it was sluggish, now does not work at all. (Brushes & commutator service)
-Port engine runs nice mechanically but has a fuel problem with carb or fuel pump, it will not accelerate, rather it stalls. I can run out of gear all day long though.
-Trim tab motor is inop, not sure why.
I know this sounds ugly, but other than the transom, the problems are fixable. Redoing a transom is not somthing I can handle from a skill level or physically. Engine work I guess I can do, but after finding the transom, why bother.......
Looking to take back to the auction and dump for whatever somone will pay & take a loss. Or would I be better pulling the two engines & drives and paying about $600 to scrap the hull. I know right now I will not be breaking even either way.
