Preventive Maintenance
foxden
Are there any symptoms for an engine that needs to be de-carbed, or is it just a matter of preventive maintenance? The same question applies to carburetors, should one "re-build" theirs every so many years or wait for problems?
JB
Re: Preventive Maintenance
Great question, foxden. It deserves discussion, but it is a general outboard question, not a trouble.<br /><br />Moving to General Outboard.
james roach
It's been my experience that there are no warning signs until a ring breaks and you are up the creek. I was riding in a friends boat once and a ring broke about a mile from the ramp after riding all day (35 miles). Other than a low compression reading I cant think of any other possibilities. To decarbon a motor is preventative maintainence. I have known them to run better after the decarbon process.
glass from the past
Hey Foxden,<br /><br />I noticed on my motor (79 Chrysler 40 horse, 2 stroke) that I would have trouble getting the motor to hold a low idle and I had a hard time starting it, 4 or 5 times with the key. After decarbing and a fresh set of plugs A-OK. I am told this is due to the reeds getting carbon buildup and they do not meter fuel correctly.
foxden
Followed the general advice and decarbed my engine. Runs great, starts quickly and accelerates smoothly from idle to WOT. Thanks for the help.
quantumleap
Master Chief Petty Officer
foxden, just out of curiosity, what method did you use to decarb? :confused:
foxden
I mixed 3/4 gal fuel, 1 can seafoam and 3 oz oil. Warmed the engine up on muffs and then changed from the regular fuel to my mix. Kept the rpms around 11-1200 for about 15-20 minutes and shut it down for at least 20 minutes. Started it up (smoked a bit at first) and ran for another 20 minutes. Shut down, waited, etc one more time. I have a 90 hp Yamaha and I wound up using about 1/2 of the mix in total.
