pretolite tilt valve help
dzer57
have a 1970 merccruiser 470 with prestolite trim pump (plastic square bottom)
rebuilt trim valve (unstick shuttle)
any one no proper amount of turns for relief valve (removed and didn't recornd turns from bottom out)
3 valve
1 soft ? valve hypressure side
1 with bearing hypressure side
1 with bearing low pressure side
trouble iI am having is motor kicks (trips point connector in motor wait several seconds works again) out before cylinder go up or down completly
motor works fine with no load
thanks for advise
Don
