Re: Prestolite trim pump cable
Go to your local electrical wholesaler and ask for a tinned two core flex with rubber insulation, your big problem will be taking the motor apart and brazing the cables back on the brushes. My suggestion would be to take the tilt trim pump to a motor rewinder and ask them to replace, it may cost you more, but I have found it nearly impossible to reconnect cables onto the brush section. The last two times I pulled these motors apart, the cables broke off the brush housing, mainly from them overheating in the first place and one had moisture in it which slowed it up till eventually it stopped due to rust in the brush housing. Seems strange they would cut the cable if, unless the motor didn't work?
