K&C Speed
- Jul 18, 2021
- 8
Good Day
I'm looking for help on my old Prestolite trim pump 1977120 Mercruiser MC-1. I had everything off and apart to rebuild my transom. I reassembled the trim assembly, wiring and hydraulic lines what I believe to be correct.
The leg trimmed down ok. but not up.. Won't go up in neutral.. Actually, I cant even get a click from the trim solenoid. I put my control in reverse.. I can get the pump to activate in the up position (laboring I might add) with hydraulic fluid shooting out the bottom of the pump reservoir.. I think its the the return line where its coming from.. but not really to sure. This Trim pump was working prior to me removing it last fall. One button down and two buttons up and out. the single button up for trim was not functional. The power fuse and circuit breaker were absent.
So, I'm new to boats but willing to learn.
Any suggestions would be greatly appreciated as I have come to a place I'm not really sure what to do from this point forward.
Thank You
Thank You
