MostlyHrmlss
- Mar 18, 2008
- 57
I have a 1985 85hp, with the Prestolite ignition. The 1/2 CDI box and coils are all black in color, but the #3 CDI and coil are blue. The wires from the blue CDI were spliced to the original harness, correctly as far as I can tell. I'm having ignition problems, and would like to swap out parts The thing is, the wires between the coil and CDI have the opposite genders on the blue and black boxes, so I can't plug the blue coil into the black CDI, and vice-versa. What I have in mind is cutting the connectors from the wire between the blue CDI and coil and splicing them back the other way, like the black ones are. This begs the question, are the blue and black components compatible, other than the connector gender?
