keithm1961
- Jan 29, 2010
- 46
Replaced all the seald and orings in a 1976 Johnson 85. Went to lake test and found water in the oil. I drained the unit and pressure checked the unit at 10 lbsfound leak at the shift rod. The shift rod has no seal but does have an oring under the cover. There is a lot of play in the shift rod. I pulled the lower unit off of a 75 model and pressure checked it 10 lbs held for over 30 minutes. I noticed if I shook the shift rod back and forth it would leak air also. Why is there not a seal on this shaft do they not have problems with water entering thru there. All the seals and orings in the parts diagram are there. I've looked at a few of these and discovered they all have a little slopiness in the shaft. Any ideas where else this water could be coming from.
Thanks
Keith
Thanks
Keith
