goldenmonkeyboy
- Jun 3, 2003
- 12
I have noticed when I go full throttle high revs the water stops coming out of the water pump telltale. Its a Johnson 1998 70hp and the manual says the water circulation in the cooling system is controled at low revs by the thermostat when the engine goes to high revs the water is controlled by the pressure relief valve. Is my valve faulty or is it common for the water telltale to switch off at times
