Re: Pressure reg/Vapor separator
Dave,
I doubt that there is anything wrong with the fuel pressure regulator. I initially thought that mine might be bad and ordered another ($100). In fact it just came today. In the meantime, I have run it and everything is fine with the fuel system and fuel delivery. I may change it out anyway.
VST (vapor separator tank) acts as a holding reservois for the high pressure fuel pump. Your oil pump actually injects oil iinto the VST so that it is pre-mixed with fuel prior to being sent through the fuel rail to serve the injectors by the high pressure fuel pump. The low pressure (pulse) fuel pump keeps the reservois filled and there is a float with needle valve in there. You should hear the high pressure fuel pump come on when you first turn the key to the "on" position (not start). It'll run for about 15 seconds or so and shut off. High pressure pump should put out about 32-34 psi. Fuel pumps into the fuel rail throuogh one of the two tubes previously mentioned and whatever is not needed by the injectors comes back through the second tube, through the pressure regulator, to the reservois. It's like a small closed high pressure loop. There is a discharge valve (looks like a tire valve) adjacent to the presure regulator for discharging the system. Beware, if you need to open the VST, there is an o-ring gasket that is not going to be re-usable and you'll need a new one (about $30) as the old one stretches too much to re-fit it into the groove on the tank. If you have fuel delivery issues (bogging when you try to throttle up) and your high pressure pump is working, it may be that the filter at the bottom of thhe pump is varnished up and clogged (it has a very fine mesh screen). You can clean this with a degreaser and re-use it if you are careful. It removes with a clockwise twist of about 15 degrees then pulls off. If your high pressure pump is not coming on, it could be gummed up. I've heard that they can sometimes be made to work again by soaking them in Seafoam or Berriman's B12, but I didn't try. A new one will cost you $400-450 at an aftermarket outlet or $600+ through Mercury. Comes as a kit with a new filter and carious o-rings.
If all you are experiencing is the leakage through the vent fitting, it's most likely just the o-rings because that part of the system is under pressure from both squeezing the ball and from the pump once the key is turned on. Pull the hose fitting off as I described and pull the fuel tubes out and inspect the o-rings. If you need to order them, go to an aftermarket o-ring supply house. You'll need to measure them (ID and thickness). I bought extras ( they're about .25 each). If you go to Mercury, they're not available separately, only as part of a kit that costs aboout $250.
Let me know if you have any other issues regarding the VST. I just finished dealing with mine a few weeks ago and know this part of my engine fairly well.
Jim C.
