Pre-load pin on driveshaft?
clydey
Might be an easy question for some....what is a preload pin on the driveshaft?
thumpar
Re: Pre-load pin on driveshaft?
I think you are talking about the preload pin on the vertical shaft in the drive. If you have your drive apart the shaft that goes into the upper unit from the lower unit can have a pin at the top of it that is spring loaded. That would be the preload pin.
