pre ignition detonation
droptheline
does pre ignition detenation sound like a standard car running in a high gear at low rpm? i have been having some issues i thought was due to improper propellar pitch but have been duing some investigating and think this might be the problem, gonna get a advance timing light and set the points. any one know the specs? thanks
JustJason
Re: pre ignition detonation
I know the specs for the 07 3.0L Merc I just finished up. :)
my bad , 3.0 89 mercruiser
Ayuh,... The factory manual has the Info you're lookin' for,...
And,..
The factory Manuals are found up in the Adults Only section for you to download....
cooter2506
It depends on you distributor. Is it Delco or prestolite
Rocky_Road
This is for the 3.0L...3.0LX is different:
AC plug...MR43T
Champion plug...RV8C
Plug gap...0.035"
Point gap...0.022"
Point dwell...28-34 degrees
Timing...6 degrees BTDC
Fuel pressure...3-6 psi
Oil pressure @2000 RPM...30-60 psi
Idle RPM in gear...650-700
WOT RPM...4200-4600
