We're talking about 2 or 4 strokes OB's as Honda is a brand that don't work with. Can you sit a 7.5 and a 10 HP powerhead on any of both middle leg units ? With which one should stay ? depends on how much work you need to do along costs. As I like doing partial and full restaurations would go for the larger 10 HP, if cylinder walls are impeccable perfect round and within factory specs will only need to change piston rings, head gasket, base gasket. Worst scenario, if not within cylinder specs, rebore cylinder to next super size.
The only way to warp badly a cylinder head along blowing a head gsket is by means of a severe overheat due to lower leg picked debris, algae, plastic bag, even a banana peel while OB was revving high and you weren't aware of this condition, usually will find a melted impeller inside liner due to running dry for extended time.
If head gasket has not been re torqued after break in period has ended expect some water intrussion on cylinders which produces corrotion, oxidation if OB was left siting for extreme long time periods. Worst if OB was used on salty waters.
Is it possible to weld cracked 7.5 to original condition and use while the 10 undergoes restoration ? At least will not be left stranded at home while other boaters are having great boting time. LOL!!
Happy Boating
