Evinrude 70 hp 1977<br /><br />After rebuilding carbs, waterpump, fuelpump, fuelhoses, mainseal, checked compression ok<br />It ran fine for a year than the powerpack failed<br />got a used one it lasted for about year<br />got another used one it lasted about 6 months.<br />Just got a new powerpack and Rectifier it did not work at all.<br /><br />The boat will rev. up fine under no load<br />but as soon as you put load on it (put it in the water)<br /><br />It will only idle and the more throttle I give it<br />it sounds and acts like it is flooded<br />will not rev. up<br />(only when in neutral it will rev up fine)<br /><br />also checked for rev. voltage short going back to the powerpack from the key none was detected (black/yellow wire)<br /><br />help ?<br />megclay
