The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
I am attempting to remove a powerhead on my mercury 4.5 HP. I removed 6 nuts from the lower side of the motor(surrounding the drive shaft housing) and I can't get the powrhead to budge. What have I missed ?
I just had this problem before took of the nuts tryed to get it up no go I found that if you remove the studs put two nuts on the bottom lock them in them get the studs out I had a little corrosion around them stoping it from coming off it came straight off then .
