Re: Power Winch Hookup
Break out the wallet, because you simply are going to have to. I'll tell you how I wired mine and then I'll tell you some less expensive alternatives.<br /><br />First off the plug that goes into the Power Winch is specific to their products, so if you don't want cut a hole in the side of your winch for some sort of micky mouse attachement to the switch you're going to have to buy their plug.<br /><br />On my truck I have a cable run from one of the batterys to the rear bumper. The cable is #6 battery cable (apx. $30), it runs along the frame and is held in place every foot or so by zip ties. At the rear bumper, or at the hitch actually, I feed that line into the female side of a trolling motor plug that was made by Attwood ($8) that has a spring loaded cover. I have the male side of the Attwood trolling motor plug ($8) spliced into the standard Power Winch plug, the one you're going to have to buy.<br /><br />So when we get to the ramp I simply take out my connector with the trolling motor plug on one end and the Power Winch plug on the other end and plug it into the truck and winch and crank the boat on. Its always hooked up and ready to go. Now, here's the real upside to this plug on the back. If you want to you can use it to charge other batterys, or even to give a quick jump start.<br /><br />To do it for less money just buy the power winch plug, hook it up to a few feet of cable, and put a set of alligator clips on the end. You better make sure that is all heavy cable and heavy clips though because I have to tell you, any thin stuff is going to get real hot in a big hurry.<br /><br />Oh, if you think that plug was expensive you should see what the switch cost when it goes bad. I had to replace mine last month (had to hot wire it at the ramp). Fifty Five bucks for that bad boy.<br /><br />Thom
