MrSparky37
- Jun 14, 2018
- 3
Power trim quit working, I know I am getting power to the motor, I replaced the motor and pump assembly with a 2 wire system. If I push the up or down switch a couple of times, it blows the 30 amp fuse now. You hear the relay click, motor tries to run but then the fuse blows. It was doing the same thing as when the other pump and motor were on there. Before I could tap the side of the motor with a rubber mallet and it would work again. Any ideas?
