Power trim / tilt working intermittently.
jenkir21
My 86 Sea seville has developed a problem with the power trim. It has started stalling out. Sometimes it work fine then it is completely unresponsive. Got into a tight spot this weekend when it wouldn't trim for towing luckily I aviod any contact with the ramp. Any ideas on the cause of this issue and suggestions where I can find parts for this boat if necessary?
jerryjerry05
Re: Power trim / tilt working intermittently.
More info please.Year,make, model. Last tune-up.Any thing you can think of.It could be as simple as corroded contacts or a piece gone bad.Jerry
My 86 Sea seville
Ayuh,... That don't help abit......
We need ALL the Info on the Outdrive,..... Not the Boat....
Btw,... Welcome Aboard....
jenkir21
I'll get the info and some phots of the installation to get started. Is there anyway to raise it manually ?
jenkir21
Please see attached photos. When I push the trim button there is a defined click coming from the pump assy I tapped the servo assy attached and it seemed to work again. However when I started the engine it kick out again ?
