Power Trim System
Deedallas
I have a problem with a 00 Johnson trim system. The motor settles back to the trim stop in approximately 5 minutes while under power. The only solution I have been given is to replace the unit. This is a costly solution, that maybe due to a bad seal. Can anyone give me a trouble shooting sequence that would help in determining if the unit must be replaced, or the location of a after market repair shop that makes repairs on power trim/tilt units?
superman
Re: Power Trim System
Hi Deedallas: The first thing is check and make sure your manual release valve is tight. It should be located on the trim pump. If it is it sound like probably the o-rings are bad. Good luck.
