Power trim question
Sugo
Getting ready for start up after a mercruiser re install and I have noticed that the power trim resevoir on the pump is empty. (I have not removed any lines) I will top it up before trying it out but will it require bleeding ?. Thanks for the input, I am in uncharted waters.
dubs283
Re: Power trim question
to bleed run the drive up and down 3-4 times, re-check fluid level with drive in full down position and add as necessary
the system is self bleeding
Pete104
You fill that resevoir while the drive is down
Sugo
Good to know, Thanks again
