Power trim motor harness
1Moredrift
I have a 2001 350 MAG MPI Horizon with a bravo drive. The wiring harness for the power trim is corroded and needs to be replaced. Its basically three wires into a male plug, and three wires out of the female plug that connect to the up and down selenoids on Trim motor and the third goes through a 20amp fuse and I believe back to the trim switch.<br /><br />My question is, do I really need to pay $50 for the wiring harness from Mecruiser? Is there an aftermarket product that costs less? What does the "plug do other than make it easier to install the trim motor?
Fishermark
Re: Power trim motor harness
You can splice the wires and bypass the plug completely.
