Power Trim - Merc 350
dmilnor
Any help would be appreciated.<br /><br />I just bought a 92 Cobalt Condurre 222 with 350 Mercrusier. First time in the water with the boat and the power trim would not go down. There is a series of clicking when we put it in the up position, but nothing when attempting to go down. <br /><br />Is this a Power Trim Rely Switch problem - if so, what can I do to verify before I pull the boat back out of the water. I've rebuilt power trims several times on outboard boats, this is my first attempt at I/B Stern Drive boat.<br /><br />Thank you - I'd appreciate any and all feedback.
Re: Power Trim - Merc 350
No Reason to pull the boat.... Everything you need to address is Inside the Transom.....<br />Grab a Multimeter, or test light,+ Start Chasing the Power.... Start at the batteries,+ work your way to the pump......<br />Also Check your Ground Curcuit.....
