Power trim for 77 Johnson 85hp
Al
I have a 1977 Johnson 85hp outboard. Will the old style trim/tilt that has the cylinders on the outside of the motor work?<br /><br />Thank you, AL
Dhadley
Re: Power trim for 77 Johnson 85hp
Before you decide to go that route, look at www.cook-mfg.com and check out the PT-130.<br /><br />Good luck!
Al
I already did but it interferred with my steering setup. Thanks !
Dhadley
What kind of steering set up do you have?
Al
It is custom made. But could you or anyone else tell me if the power trim unit I described will work? Thanks for your help. AL
