ledouxmike
- Jun 22, 2010
- 12
I broke my pump cylinder on a huge stump. Trying to find a used assembly on ebay. I'm wondering if the optimax and 4 stroke 115's will fit without modification. Thx Mike
Ok. I got my power trim in from eBay. Can someone tell me where I can get a 2 wire to 3 wire conversion kit for cheaper than 70 bucks. The new power trim has 2 wires and my old one had 3 wires. Thanks. Mike
db electric has them for $30. You can pull the 50A ATC fuse and replace it with a 30A self resetting circuit breaker. costs a few bucks more, but its a better deployment. as regards install - it is incredibly simple thing to do. pull out solenoids and drop in relays. use solenoid mounting screws to hold down relays. plug switch and motor in same way as before. no common ground on 2w. make absolutely positively sure to install the ground strap to anode or you will eat your system up in just a few years. if you can't find what you need on iboats, ebay, or amazon then pm me. I have about 80 of these things on hand.
