Hi guys i have here a 83 model v4 90hp johnson and ther is a screw in the side of the trim/tilt with an oring around it is this a pressure releif valve or an air bleed of some sort as the trim/tilt is not working and once i pulled out this screw i found half an o,ring on it. is there a procedure to bleed it or? any help would be appreciated
