power trim 2004 honda bf50
rich bellem
My trim gauge is showing the motor much lower then it is , and when the motor is in the full up position the gauge shows motor normal (mid point)trim position rather then full raised position . Does anyone know if there is an adjustment to get the gauge recentered ? This just started to happen. Was ok till last time out.
Re: power trim 2004 honda bf50
If you trim your engine up in max upper position, you will see a little contact with a little arm, on the left or right side. This is the trim indicator and it`s proberly not moving. Give it a little massage and some wd40, and it will work just fine again.
