spudjunior
- Oct 11, 2003
- 12
I JUST hooked up my power tilt to my boat,and cannot get to work .I have two wires that come from the tilt motor,blue/green,hook to bat they go up down,then off the black box which consist of power and neg wire,and two relays,then theres two more ground wires on diagram that looks like you ground back to the motor.The only thing that happens when you push trim switch on handle is they click,the fuse is good in box and all wiring looks correct.plus 2 new relays. ANY SUGGESTIONS, THANKS RON.
