power tilt and trim problems
ceshenb
i have an 1989 85 hp force, my power tilt and trim works fine up and down but it wont stay up it will drift down on it own. what are some if the issues i could be facing?
jerryjerry05
Re: power tilt and trim problems
Sounds like the pump needs to be replaced.There are some on e-bay but be careful what you buy.Guy on here RRITT works on them.Send him a PM.J
RRitt
the pump has two parts. motor + valve body. To fix one you need to take both parts off the boat.
bleed down is almost always caused by check valve failure in the valve body. I used to say chinese stuff would be okay on an 85HP but I'm starting to have doubts.
It is such a pain to get pump off engine that it is often worth rebuilding your motor. The red flags for motor are rust stains around top bolts or side gasket joints. If you see either, then go ahead and do motor at same time.
at any rate its not a terribly expensive fix but its not super cheap either. It's cost you $100-$300 and a saturday afternoon.
ceshenb
Thanks guys i will just go ahead and rebuild the the motor and replace the check valve when i done this boat will be brand new lol.
Thanks again
