Power Steering Pump Bolts
BlueAgave
1986 Formula 206LS with a Mercruiser 260. The power steering pump has two bolts in the back and one in the front for mounting and tighening of the belt on the pulley in front, or so it seems. My question is, are all of these bolts welded into the pump, or are they actual bolts that are screwed into the pump. I seem to have had the bolt snap while adjusting the belt and wandered if I could try to get the bolt out, or if I need to buy a new pump all together.
Re: Power Steering Pump Bolts
They're bolts......
