Power steering pulley removal
cobra 3.0
On my 3.0 OMC 1986 cobra, I need to remove the pulley on my power steering pump to put back the ajustment screw(s) under the pulley that came loose and fell. Is this pulley taken off with a puller or is it srewed on? (I see an allen key hole in the center of the shaft.)
Don S
Re: Power steering pulley removal
There is a puller that removes the pulley and another that pushes it back on.<br />If the screw fell out, you can put it back in without removing the pulley.
cobra 3.0
Thanks. I must have fat fingers because I tried for about 10 minutes and couldn't do it. :(
rodbolt
cobra<br /> its doable<br /> its not easy but its doable.<br /> the puller kit is about 50 dollars at napa. its a universal kit that doeas many pumps for GM,chysler and ford.<br /> but its common and it is possible to reinstall that bolt with the pulley in place if you can grab it.
