power packs ????
79ESKIBOT22
i have a 1971 johnson 100esl71...i have no spark ....i was going to change the points and condensier but this model does not have points .... after reading several posts from this site i thought i would try to buy a new power pack ...well when i called the local shop and asked for a "power pack" he didnt know what i was talking about .....is there another name for the power pack ????? also is there something else you would do first instead change the "power pack " or what ever its called ...the stator looked a little "burnt" in spots arond the magnets .....any help would be great ....i have a manual on the way but would like to try and get boat running soon .....
Joe Reeves
Re: power packs ????
79ESKIBOT22.... I have one new OMC improved universal powerpack left in my remaining stock. If interested, contact me at: ReevesJ32@aol.com<br /><br />You can check your powerpack as follows:<br /><br />(Battery Capacitance Dischage Powerpack Test)<br />Various OMC Engines - 1968 to 1972)<br /><br />Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. <br /><br />Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire). <br /><br />Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed. <br /><br />Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.
