Power Pack test
100es72r
I have a 72 Johnson 100hp with the single power pack and single coil on the back of the power head. There are 5 wires going into the pin connector from the power pack. Is there any way that I can test that power pack? I do not have any spark at all on any of the four cylinders. The motor was running at 3/4 speed, then died. Restarted a couple of times and ran shortly, then died. Now, no spark at all. The power pack was replaced once several years ago when Dad had it. I kind of remember similar symptoms then. I do not want to guess and spend $300 for the pack and find that it was not the problem. Thanks.
DHPMARINE
Re: Power Pack test
Generally it is the amplifier,but sometimes the sensor under the flywheel.Also you have a clipper circuit,that is hard to diagnos.
Because of the scarcity of parts,as well as the cost ...
Maybe find someone who can actually diagnos this in person.
DHP
100es72r
Re: Power Pack test
DHP
dsinger
Re: Power Pack test
Better yet how do you test the coil on that motor because I have the same problem and the only thing left on mine that is not new is the coil but want to know how to test a coil. I have asked this question several time but never got an answer.
