Re: power pack output
Ken,<br />I also ment to ask if you got around to connecting your meter, per my last post. Perhaps I wasn't too clear, I'll try again. Place the Red meter lead to the powerhead. This is a positive ground system. Find the kill switch. It should have 2 wires. One wire will be bolted to the powerhead, ignore this wire. The other wire should go into a wireing connector. Straighten a small paperclip and insert the paperclip into the wireing connector, for that wire, making contact. Connect your Black meter lead to the paperclip. Don't disconnect the wireing connector.<br />Place your meter on DC volts, and start the motor. You should read the output voltage of the powerpack.
