Good evening friends,<br /><br />I posted a while back thinking i may have dropped a cylinder in my '88 40hp johnson; after checking the compression (120-115) im continuing the search for my problem. Went out one day with the engine running rough at WOT, and on the final decsent home (not very far) it cut to half speed and bogged down. tinkered with it and charged the battery and tried it two weeks later; started up and idled fine, but again, right off the bat bogged down at WOT. If it got on plane all day it was not for 5 seconds before it would cut out. Have done some preliminary checks on the fuel system: the fuel pump looks to be pumping gas sufficiently and the carbs look to be in really clean shape. To get to my point, i want to test my power pack to see if it may be the culprit; I tried one test i read in Clymers by using a voltage meter and sticking the positive probe up in the boot of the leads coming from the power pack. supposedly if i get anything less than 200 volts the power pack is toast; i got maybe 20 volts. Anyone know of any other tests that are easily done by a novice or any other suggestions as to what my problem may be? <br /><br />Thanks so much
