Re: power pack or stator?
lorin that came out more smart-xxx than I meant...your point is good and I couldn't find the connection either...but not being an engineer I just accept it.
hydrick, it takes upwards of 10,000 volts to make the spark. You could probably use a regular voltmeter to measure AC coming off the stator to the powerpack...and get a voltage/no-voltage determination, but it wouldn't tell you what you need to know which is whether it is sufficient.
Someone here posted an idea about measuring the powerpack capacitor output with an oscilliscope.
And, Paul Moir provided this schematic for fabricating a DVA - it's just a full wave bridge rectifier with a smoothing capacitor. I haven't got around to trying it out yet. Set your DMM for DC volts and add 1.4 volts to your reading to compensate for voltage drop across the diodes.
