Power loss question when starting
Newbieboatguy
Hi I have a 95 bayliner capri with a i/o mercruiser 3.0. I can turn the key and even crank it over with the switch off by the throttle. When i switch it to run and crank it I lose all power to my gauges and it doesn't crank. Then i can come back hours later (or the next day) and I right back to where I started....any ideas would be greatly appreciated!
your key switch may be flakey. use a test light and do some diagnostics
