DistantGunfire
- Jan 12, 2012
- 16
Hi,
The last few trips out with my 70's model 105hp chrysler have felt to be lacking in power.
My boat is a 15 foot Volero Arrow and my top speed is about 35mph on a 19 pitch prop.
Now the problem I have is the engine seems to be down on power. I often tow 2 tubes behind the boat and taking off and getting to plain isn't usually an issue. Now it is somewhat. The engine struggles to get up and going. Once on plain the power seems ok but not what it was.
The idle is quite rough now also. The engine starts no worries cold. Hot starts can be hit and miss with it sometimes dying from too low rpm but on the second crank they slowly come back up. Neutral idle is around 1500rpm. 7-800rpm in gear. But rough.
I have noticed the engine is smelling of fuel when running. Like its running rich. The idle screws are both aprox 1-1/4 out from seated.
When I first got the engine a year ago I replaced the fuel pump, water pump and housing, all fuel lines, fuel filter between fuel pump and carb, new primer bulb, new tank. I also cleaned and sync'd both carbs. It has been out many times but only now am I seeing a decrease in performance. It just doesn't pull like it did or idle for that matter.
Could this be an ignition/spark related problem or something more sinister?
It definitely smells as though it is running too rich or is not firing properly. Plugs are gapless new NGK showing a blackened centre electrode and oil on threads when removing from head.
Oh and compression on all 4 is between 145 and 140 psi.
Any help appreciated!
