tkriverman
- Aug 9, 2006
- 9
I have an 86 glastron 23' w/cc. It has a 205 v6 mercruiser. I drained the oil and about 2 gallons of water came out then some milky grey sludge. I pulled the heads and cleaned it all up. The pistons and sleeves look good. I checked the outdrive and the exaust boot had a tear in it. could this be where all the water came from? I still have the engine apart (heads off) is there anything else I need to do? Would this be the cause of loss of power? I also took apart the lower unit and checked u joints etc.. all ok except for water in lower unit oil. wot I should get 42-4600 rpm, was only getting 3000.
